car play maps voice guidance volume
Hi all
I have car play in my NX 300 and I use the "maps"  navigation when needed, only problem is the guidance voice seems to have only 1 level of volume !! Has anybody found out how to reduce the voice guidance level when using car play navigation apps ? I have tried the obvious, turning volume down on car audio, no difference, also on my Iphone there is a setting on maps guidance with 4 levels of volume .....high, normal, low, and off. neither of which make any difference to the actual car volume.
If anybody knows the answer I would grateful
Many thanks
Roy
I have had the same issue and it seems that the only way to change the volume is via the voice volume via the car settings as you have found out.
