It is the coolant filler for the engine so you may get some coolant come out. Only do it if the engine is cold.
There is also a seal with the nut, as Colin correctly mentions little will escape with a cold engine as the thermostat will be fully closed and leaving the pressure cap on will also help minimise loss of coolant
4 hours ago, MerchantOfVenice said:
Can I safely remove this nut to replace it?
Oh man I though it was just me and my OCD!!
I cheated though - I sprayed all my rusty looking nut heads in my engine bay and wheel arch with satin black
2 hours ago, MerchantOfVenice said:
I’d like to stick to oem!
progress with the engine bay
I assume you'll be straightening the oil filler cap when you've finished?
:wink:
is there something amiss with the top of the brake fluid reservoir cap !
