Unable to play mp3 music on USB memory stick
I wonder if someone can help me.
I have just part exchanged my 2014 Lexus IS300h for a 2019 one. On the 2014 one I could play music (MP3) from USB memory sticks. On the 2019 one I cannot even though they are the same memory sticks from the previous car. There is power to the USBs because the light at the tip of the memory stick comes on and I can charge my phone. I have tried unplugging, plugging back in again etc. The USB 1 and 2 in the source menu are greyed out and cannot be selected.
Any ideas?
Hi Chris,
I assume the stick still works in a computer?
Did you also try a different memory stick in the new IS?
Can I ask what brand of stick it is?  There have been issues with the early release of at least one sandisk usb stick when used in vehicles. The ultra-fit I think it is.
Paul
The problem with USB flash drives is that they were never really meant to be 'permanent' storage, merely just a means of transferring files from one device to another. Their failure mode rarely gives any warning and I have literally seen them be alright at, say, 10am and completely given up the ghost half an hour later.
I've got one which works on two of my laptops and not another. I've also lost count of the flash drives I've had over the years which suddenly go "poof". Don't get me started on CD-Rs. I dug out some from the early 2000s yesterday and about 25% were unusable. It's lucky that I haven't had to refer to them in the past 20 years... .;-)
I had this problem when I first purchased my IS300h back in Feb, I have a Mac & it wouldn't recognise anything on it.
I ended up using my Son's Window PC & formatting in Fat32, that seemed to to the trick.
Thanks for your replies. Yes the USB memory stick plays on my desktop computer with no issues. I do not know who the manufacturer is, the format is FAT 32.  I bought 6 from amazon and put audio books on them to play in the car. I have tried a couple of others that worked in my previous Lexus and they do not play in this one either. I have copied the present one on to a CD which plays ok on the Lexus CD player, thank goodness Lexus have not done away with CD players yet like some other manufacturers have.
The car has come with a 12 month warranty so if I cannot cajole the USB sockets into working I will see if the Lexus garage can fix it when I take it in for a service.
Chris,
If you can, try copying the data to another stick, preferably another brand of stick.  If there are still issues, it sounds like a vehicle problem.  Sounds like you have set everything up properly (fat32 etc).
Cheers,
Paul
