Sat Nav Command
According to the Dealer there isn't a verbal command and has to be done through touchpad. I'm not convinced. Going to practice my American/Japanese accent and keep trying.
I've not found one, despite extensive searching (and shouting!!) one has to select cancel from the nav menu.
Unlike the Merc where one simply says "Cancel navigation"
On 5/29/2021 at 10:46 PM, Gorb said:
Does anybody know the sat nav voice command to stop guidance?
There isn't that i know only as Peter@nemesis mentions via touchpad.
On 5/29/2021 at 10:48 PM, royoftherovers said:
Handbook might give a clue Gordon ?
LIke others on this thread I haven't found such a command. Can you be more specific than just Handbook John?
There are 2 Handbooks Barry, one for car and one for Navigation. Within the latter there should be a list of commands that can be used. I asked if you had looked at that.
In my GS, If I press the nav button while nav is in use I get the option to suspend guidance. Do you have that available to you ?
STAAAAARRP!!!
Just a thought….😊
