2002 LS430 rear parking sensors part numbers
DMNEL
Hi, I'm having trouble confirming the part numbers for the rear parking sensors. Also are two different types of sensor used on the rear bumper?.
Regards DMNEL
It looks like there are different types for the centre section and sides, there are some on Fleabay claiming to be “ genuine” but the provided part number doesn’t exist.
Found these on amazon but again duff part numbers and only lists 2003-2006 facelift models.
https://www.amazon.co.uk/Ultrasonic-Reverse-Parking-89341-50011-8934150011B0/dp/B018TR4KHE
Give LexusPartsDirect a call they will help you with part numbers and supply.
  • 11 months later...
How easy are they to replace. I have a 'temperamental' one on the front bumper. Can you get at them from behind easily?
On the 2000-2003 the front outer 2 sensors and the rear outer 2 on each side are 89341-50010 or 89341-50011.
The middle 2 sensors for both front and rear are 89341-50020 or 89341-50050.
https://lexus-europe.epc-data.com/ls430/ucf30r/5107/electric/8417/
On the 2004-2006 you have to take the bumper cover off to access all but the outer sensors (1 right & 1 left) on the front.
I have not had to do the back yet.
