IS200 fuel injectors
Hoping someone can fill in the last bit of information I'm missing.
Recently been looking at throwing a supercharger onto my sportcross, jumped into it today and I think one of the fuel injectors has gone bad after some code scanning and tests. One of the recommendations anyway for installing the charger is to upgrade the OEM injectors to the 1zz-fe ones.
I know the injections as standard are high impedance but before I pickup some 1ZZ ones (here is an example https://www.ebay.co.uk/itm/Fuel-Injector-For-Toyota-Avensis-Celica-Corolla-Verso-MR2-1-8-1ZZ-FE-23250-22040-/353221957338?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0 ) which when checked on the denso spec list ( https://www.injectorrx.com/fuel-injector-cleaning-and-flow-testing-service/fuel-injectors/fuel-injector-data/denso-fuel-injectors/ ) come up as 13.4ohms, 255 flow & 24lb.
I can't find the OEM injectors on the list though. Can someone confirm if the above advertised 1zz injectors are the ones recommended for the charger upgrade?
