Hi My Aircon stopped working suddenly. I have checked relay, clutch engages and I have topped up gas to required level and it still does not work what could it be. There are no noises coming from compressor either.
Many thanks
Darren
Is the AC light flashing?
If you get a lock out then you need to clear the error before the system will allow it to come on again. You can either pull fuse ECU-B2 for 30 seconds or disconnect the Battery for 30 seconds. I believe that fuse is in the passenger side footwell, but could be driver side (not 100% sure which side).
If that doesn't fix it then we would need to obtain the error code. Do you have sat nav? As the procedure for getting the code is different.
