2010 RX450h - 'Vehicle Customisation' Menu missing?
Hi all,
I've got a 2010 rx450h with the nav/mmi system. When i navigate to vehicle settings on the system, typically there's 3 buttons. First is 'maintenance', second is 'LEXUS park assist' however there is no third button. I know for sure this third button should show 'vehicle customisation' because i remember i've selected this a while back (maybe 1 or 2 years ago).
I'm now trying to get to that menu but its missing - i'm not sure whats wrong. I've made sure the car is in park with the handbrake on.
Anyone else had this issue?
Could be wrong as it's been a while now since I had a 450h, but I seem to remember that the customisation screen is not on the main satnav screen, but is between the speedo and rev/eco dial?
My 2014 RX450h is the first I've owned, and I'm not familiar with your terminology 'vehicle customisation'....(though maybe I should be!)
Following up on Dan's post above, are you perchance referring to the toggle buttons on the r/hand side of the steering wheel, which together with the menu button, enable you to choose Eco, std (and in my car Sport) modes etc?
You should be able to use this button to move right and left and select different menus. One is a customisation menu that allows you to change the sensitivity of the light sensor, another to change what triggers door locking/unlocking (i.e. speed or gear selection in and out of P), easy access (partial/full), etc. Most of the customisation options are only available when the car is in 'P' (not accessible in Drive mode).
As I said, it's been a while since I've owned an RX but I'm sure someone will correct me if I'm wrong.
If in doubt, you may need to check your handbook (vehicle customisation or just customisation). You can download one from the Lexus website.
On 8/6/2021 at 8:52 PM, RXboii_786 said:
Hi all,
Update:
You post made me investigate on my car - - and then I realise that my previous post was complete rubbish!
Apologies
When you reach the point on your nav/mmi system, and navigate to vehicle settings - there are indeed a number of onscreen buttons - - (the vehicle customisation' button is greyed out.
Until you power up the car - - then, as if by magic (!) - the button springs into life - and you can customise all the options available
On 8/13/2021 at 3:52 PM, Illogan said:
Update:
Apologies
thanks for yours response. Mine is a 2010 model, which has the 2010 - 2012 infotainment system, quite different to the system added in 2013 (or end of 2012). Mine isn't greyed out, the button just isnt there. Its literally disappeared. I know for sure its gone because i remember clicking on the vehicle customization button when i bought the car (about 2 years ago). I've made sure the cars started, in park, handbrake on and it still isn't there...
Hi, i think this feature was added in the 2012/13 facelift perhaps, mine doesn't have this.
