I have just got my car back finally but noticed something strange and that is the keys work remotely but not actually in the door?
Any explanation for this?
Also headlight washers don't seem to work?
Headlight washers will only work with Headlights on,silly question but did the key actually work in the door before 🤔
Strange if the keys worked in the lock before and now don't,would have said if they didn't then the lock might have been changed,as for the washers could possibly be a fuse or the pump,do you screen washers work 🤔
How are you testing the headlamp washer?
They will only work with the headlamps illuminated (not just switched on auto) and only on the first pull of the stalk, after that every 5th attempt (on my RC anyway)
I had the same isue with washers when bought the car.
One hose was disconected from the washer behind the bumper and both of them did not work.
Conected it back and no problem since then.
Put the headlights on and try the windscreen washer, if you see any scree  wash liquid under the bumber then you have the same problem.
Sorry for the bad english 😬
2 minutes ago, b4u2 said:
still got to resolve this though....
any suggestions or ideas what it may be?
I had the same issue with washers when bought the car.
One hose was disconnected from the washer behind the bumper and both of them did not work.
Connected it back and no problem since then.
Sorry for the bad English 😬
which hose?
do you have photo or diagram to show me please?
PS. I CORRECTED YOUR ENGLISH!🙂👍
It's just an (RX300) example but there are lots on the internet... a quick search will help.
