quick urgent question on coolant
finest1
hi all,
i just found out my coolant reservoir has no, very little coolant in there.  google search advises to use the Toyota pink coolant.  is there any alternatives i can use?
i can source the Toyota pink, but it won't arrive until the weekend or later. i need the car for Friday. Halfords came up with a match "suitable" for my car but not sure if its a definite match
any suggestions
thanks
Lexus IS250 petrol SE-L 2006
no leaks, not that i can see anyway. was looking an hour ago with a LED torch. mind you, if there was does coolant evaporate quickly?
i ordered the lexus/toyota pink coolant. says due to be delivered friday.  i'll top it up and then i can check if any leaks. good thing i'm working from home tomorrow! i'll make alternative arrangement on friday
The cooling system is sealed. The coolant cannot disappear unless there is a leak or the pressure within the system gets too high and it is forced out. Fill it back up with distilled water and take it for a good drive to see if the level drops.
I recently had unexplained coolant loss on my RX, garage couldn't find any leaks but it had lost a fair bit. I replaced the radiator cap and it hasn't leaked since.
I would definitely get it checked because as others have said the coolant has to be going somewhere.
1 hour ago, finest1 said:
hi colin. when i inspected the coolant cap, it was loose/ajar. could pressure have built up and popped the cap? cap its self is fine, no breaks, its clips back on ok
If the pressure cap was loose that would probably explain the loss, top it back up, refit the cap correctly then keep an eye on the temperature gauge and the coolant level.
thanks Mark and  Steve, will do.
i ordered OEM coolant, which should be arriving friday afternoon/evening. i managed to arrange alternative transport for work tomorrow, so car won't be used until i add coolant to it
many years ago I had a cap that seemed fine on my old Ls400 BUT it wasn't and it's effectiveness had diminished and i was losing coolant thru that
A replacement cap then from a factor was about a fiver ......  the caps were often for multi marque use too
Just now, finest1 said:
thanks mark, i will look i was wondering whether i should change it...i'll inspect it properly tomorrow
I would first have the car inspected to check for potential leaks or the coolant going somewhere else (eg head gasket, although if that were the case you'd likely have other symptoms). My local garage didn't charge me when they couldn't find anything wrong. It would be silly to spend £28 on a radiator cap when the issue might be elsewhere, in my case I did that as a last resort after a suggestion from a mechanic I know. Apparently when they pressure test cooling systems they often remove the cap in order to conduct the test and then neglect to test the cap itself. I don't know if this is what actually happened with mine, all I know is that the garage couldn't find any issue at all, I replaced the radiator cap and have driven over 1500 miles since without losing any coolant.
23 minutes ago, m4rkw said:
Not daft, possible.
Phew - I only mentioned it because when the water pump in my '07 IS250 went, the coolant level went down. Not being too mechanically savvy, I didn't realise that the pump might be on the way out but luckily my local Indie is a wise chap.
update:
this morning i removed the plastic coolant tank and inspected it. there was no coolant in the tank and there are no signs of damage or wear on it either.
i topped up the tank with coolant and i'll leave it now to see if there are any leaks.
what i wanted to ask you was this. should i be filling coolant via the radiator cap too?
