"delayed" accessory power?
I have a 2002 is300 sportcross.
I want to install a raspberry Pi head unit, but need to give it a way to safely shutdown on power off.
Ideally, this means I need to tap into a power circuit which stays on for a few minutes after the ignition is switched off.
Is there such a circuit on my car?
Its not a big deal if not, as I can add a l delay circuit in other ways.
4 hours ago, ColinBarber said:
No, unfortunately not.
You would need a delay circuit connected to a permanent feed. Something like this (without wiring up the door switch connection).
https://www.ebay.co.uk/itm/271538416211
I'm thinking of adding a small microcontroller (maybe an esp32) as the timing controller, I can also make the wing mirrors auto-retract with it.
There'll be a write-up eventually...
