Electrical issues
NormanB
Something is draining my Battery when the car is left for a few days. Could it be connected to the fact that the warning light for automatic headlamp adjustment malfunction has come on? It's been going on and off for some time as you drive, now it is on all the time the engine is running. Otherwise, everything seems to be working normally. All suggestions gratefully received! The first time this happened, I replaced the Battery as it was a few years old. But clearly that was not the problem!
11 minutes ago, NormanB said:
Something is draining my battery when the car is left for a few days. Could it be connected to the fact that the warning light for automatic headlamp adjustment malfunction has come on?
I very much doubt it, to be honest.
Trying to find a parasitic drain can be time-consuming and frustrating but the video below is the best method I've ever seen:
