(Blue?) ISF in Farnborough
It was getting dark so I didn't get the best look, but I think it was blue, definitely an ISF. V8 at the start of the reg plate. I was out running and it was right by Ively roundabout by the airport. Anyone here?
How have I not seen you if that's local to you? I am but 5 mins from that roundabout! Haven't seen an ISF over my way for a while, maybe a new addition to someones garage... There was a grey one that used to pass me around Aldershot area frequently but has since vanished.
Ha! We must live near each other than as it's very local to me also. I'm still mostly working from home, so I'm not driving the RCF around all that much, or maybe we just haven't been on the same route at the same time.
When I feel like going for a quick spin I usually take it around some of the roads near there, maybe you know the ones, quite fun to drive and usually not that busy.
I will keep an eye out for a white GSF then.
You'll likely hear me before you see me 😂, we should sort out some spirited driving at some point as we seem to be so local to each other! 💪
