ADVICE NEEDED
Alan Needham
Hi Alan and welcome to the LOC.
To help find the Traction Control problem you will need to have any fault codes read as this should provide a cause for the TRC light being on.
Once you have the code(s) come back with it/them and we can help further, there are some common causes but guessing and replacement is an expensive method.
Regarding the coolant loss and overheating do you know where the leak is?
