Rear Differential IS250
IS 250 / nov 2005 / MTM
Ladies & Gents….. my differential story…. If you can get to the end…. a little help needed.
So I started to get a rumbling noise a couple of weeks ago.
It’s a constant noise from set off that seems to peak in the cabin at around 40mph.
The car is running fine, no engine issues, gear changes all fine, economy all normal. No dash lights. I can rev it hard at stationary doesn’t miss a beat.
If you drive with all the windows open, air con off there no exterior sound….. or when I got the wife to do a couple of passes past me in the local supermarket car park.
The rumble did not disappear if I put the clutch in and continues if I take it out of gear and coast along.
The rumble is a mechanical grumble/whirring if that makes sense….it’s not a rapid bump bump bump noise…..and not a high pitched whine.
I would have put my mortgage on that it was coming from the front end of the car…… so I stripped both front wheels, callipers, pads, discs, disc shields and replaced both hubs ( I was convinced it was the NS front hub ) and thought might as well do both while I was at it.
Went for a test drive…. Noise exactly the same!…… red face 🥴
I checked the exhaust to see if anything could be making a contact and everything looks ok…..including the heat shields.
I’ve had the wheels refurbed about six months ago so I know they are all straight and balanced, I have no sign of any adverse wear on the tyres. No steering wheel shake either, even at legal plus.
I checked both rear wheels and didn’t seem to have any play, drive shafts, joints and boots all seem to be in good order.
Couldn’t feel anything strange on the prop-shaft ( was thinking may be central carrier bearing??…. ) but it is hard to tell this diy styli on the drive.
While under the car I touched the rear diff case and thought it felt quite hot ( don’t honestly know what kind of temp it should be….warm I guess like a gearbox??) but it felt hot to touch.
First thought was low on fluid.
I cracked the fill plug and managed to get maybe a 100ml tops into it. The drain plug was dry no sign of any weeping.
I last had this changed at 60k ( now at 130k ) and was originally planning on doing it again around 120k with the plugs…. but like when I changed the plugs at 60k ( they still looked perfect ) the diff fluid was also still in great condition.
So I had put off both until the end of the year.
I’ve resisted dropping the diff fluid and having a look at what’s attached to the magnet mainly due to being a bit in denial at the time….. as this seems to be a reasonably rare occurrence.
Just for the record…. I’m not the burnout or doughnut drift king LOL…… far from it.
Finally had the back end up both sides, while a mate was turning the rear wheels you can hear the noise clearly from the differential. It’s toast….
Q) regarding a replacement ( used ) would any one fit from a 250 / 220d….ATM or MTM are they all the same ratio?
The part number I’m working to is :
41110-53191   09 2005.  Carrier Assy Differential Rear GSE 20 MTM FGR= 43:12=3.583
The are special oils for differentials that whine, 80W140 and also an STP additive directly into the differential and then fill with  80W140 GL5 minimum specification.
I had Mercedes 280CE with a whining diffetential, especially when driving about 20 mph. Applied the above prescription and it was silenced forever. Clocked many thousand miles and had no problem.
It may work for yours.
Chris.
Thank you both….. I did start to have a look at some of these types of products, as you say Paul not much to loose.
My Indy managed to squeeze her in yesterday and get it up on the ramp and also spin the wheels under drive.
it’s a bit worse than I thought and he’s advised me to do as little as possible if I can’t take it off the road immediately.
I asked about using anything of the magic potions and he thought I’d be wasting my time and money……. We had a joke about sawdust too! 😆
Hes a decent lad and probably being over cautious….. but his rule of thumb is if its a whine try the greases etc…… rumblings is the bearings squaring off so recon or replace it ASAP.
Ive been offered a used diff that seems in good condition from a is250 2008 auto with this label. They cannot see any other stamping on it.
Anyone know if it would be compatible?
phil
Auto diffs are 3.7 ratio. Manual are 3.9.. i've seen the prices of used ones and if i was to change the diff, i'd upgrade to GT86 diff (torsen lsd) with 4.1 final drive.. it'll give you a noticeable acceleration boost. I'm not sure which IS250 specs etc had open or lsd (torsen diff), but keep that in mind.. I've had my dealings with 2 manual IS250s, both pre-facelift and both with factory limited slip diff.. my 2 mates with auto facelifts also have LSD.. I presume maybe IS220d or very very basic spec 250s had an open diff. If you're going to replace the diff, make sure you don't downgrade 🙂
phil
Y55 is auto and Y54 is manual diff IIRC. Different ratios, but compatible yes. If your car is auto, you won't make things worse. If you have a manual, you don't really want the auto diff due to lower ratio (3.7) so worse acceleration but higher top speed - downgrade in my opinion.
Thanks Lucas….. that clearly explains that.
I think I saw the GT86 diff discussion on a US site as I was looking for info…… and I believe interestingly the 350 & 400 series diffs being compatible in terms of fit ( push fit rather than the previous bolt on)
My car is the very basic spec ( & I mean basic )…… so was the LSD an optional extra I wonder rather than standard??
or are they all LSD??
I’ve also seen this label from an IS220……. Any clues on ratio?
