RX450H Interior switch cluster - see photo
I'm looking for either a replacement switch cluster or the part number for my F Sport.
The cluster has the Auto Headlight switch and the tailgate release switch with the other 2 blanked off.
I have seen used replacements for Lithuania on yje usual auction site, but they have more switches,(HUD etc ) where mine is blank.
Can anyone let me know the part number for replacement, or will a used part with extra switches install and work out.
I somehow managed to crack the pushbutton and Lexus won't fix it under warranty.
TIA.
Chris.
So I ordered the part off Flea Bay from the Lithuanian guys, turned up today and is absolutely immaculate.
Now I could do with some advice on how to fit this replacement part, is it doable from the end panel  as suggested above ?
Hi Chris,
Like Les I have in the past knocked mine back into the dash. All I can say is that my dealer took around 5minutes to replace it. When I asked how they said they just took the end off the dash and clicked it back in so I guess that it will be easy to access the rear of the switch and swap over the wires. But I have no idea to remove the end of the dash!
Bri
