Wheel spacers
Hi I'm thinking of getting some 15mm spacers all round once car is lowerd have the springs ready just need time to fit. Has anyone got pictures of any fitted or has done it is 15mm going to be enough to sit flush with arch Any ideas please
  • 3 months later...
I'm also thinking about spacers on the rear wheels only, 15 or 20mm, again with lower Eibach springs(thanks SAMPLIFY)
Any ideas??
Personally, I would only trust spacers from a renowned brand such as Eibach or H&R.
There are 2 types of spacers available. The "slip-on" ones that also require extended wheel studs to be fitted.
Or, the "bolt-on" type that are fastened to the hub using the OEM studs and have their own set of studs to attach the wheel to.
For spacing out OEM wheels, the bolt-on type is more desirable IMO, since they car remains unmodified and can be returned to stock if you remove them.
With this type of spacer though, your wheels need to have cavities machined into them to accommodate the original studs and nuts that attach the spacers. I think most Lexus wheels have them.
Or, you could just cut down the OEM studs to make them shorter so they'll be compatible with any wheel, but that defeats the purpose of having this type of spacer...
15mm F / 20mm R looks good on a lowered car with OEM wheels.
i've got standard wheels so the bolt on type are the ones for me, any idea where to get them from, thanks
i've just realised you mention the brands, Eibach is the one I'm gonna source
I got some Eibach ones from amazon a few years back. Eurocarparts also sell H&R stuff.
just ordered a set from AUTODOC for about £155 , 1 set each of 15 & 20 mm though i was only planning to upgrade the rear track so i will see how it goes when they arrive & my previous question
@Lukejjwhite @samplify @ahmed-abrar
You've gotta be "careful" with spacers.. Asking what 15mm spacers will look like on your car means nothing.
What we need to know is:
  1. Your current wheel spec - width & offset
  2. Suspension setup - are you stock, are you lowered, if so, how much lower?
  3. Your goal - do you want to be flush with the arches? Bit less than flush? Do you want slight poke?
  4. Your tyres - 255/40R18 on 18x9J rim will look very different to 225/40R18 on the same width rim.
Fitment is a witchcraft and it takes a long time and a lot of math to figure out and execute well. Depends how particular you want to be. There is stance OCD or "just slap some spacers on" kinda approach.
I'll be happy to help with this if I know the above details. I know that I couldn't use 15mm spacers because the stock wheel studs were hitting the back of my wheels, so 20mm was the minimum. I ended up with 22mm spacing - 15mm hub centric + 7mm slip ons.
