Gearbox part number ?
GS3UK
What is the correct gearbox part number for a MK3 55 Plate GS300? i know its either the A960E or The A760E but what is the part number . Ive tried the EPC but it wont show the number for the complete gearbox
Looking to replace mine with a used one as it has failed and after changing the solenoid C as per the error code the mechanics have stated that the issue is still there
There is one with part number 35010-30A00 what vehicle would this be from ? i believe it is from a Japanese import
I just cant justify in scrapping the vehicle as it is in very good condition
I assume you're inferring a build date after 01.2005 Steve, how did you determine that? I wasn't sure as my own car is a 56 plate but was built before 2006.01 and so uses the parts from that earlier time range.
The part for 07.2000 - 01.2005 is different:
https://lexus-europe.epc-data.com/gs300_430/jzs160r/5048/chassis/3501/35000/
@GS3UK if you put your vin number in and then paste us the link it takes you to that would be handy so we know we have the right frame code
ah okay and so it does have the A960E box i think it was later changed to the A760E which i think is more common , both seem to be almost the same
I based it on this but on a LHD model as the Op’s status says “ non uk”
Search Results
VIN* Model code From To Frame    Characteristics
JTHBH96S.. GRS190L-BETQHW 01/2005 - 08/2007 GRS190   EUR LHD 3GRFSE
JTHBG96S.. GRS190L-BETQKV 01/2005 - 08/2007 GRS190   GCC LHD 3GRFE
JTHBH96S.. GRS190R-BETQHW 01/2005 - 08/2007 GRS190   EUR RHD 3GRFSE
JTHBG96S.. GRS190R-BETQK 01/2005 - 08/2007 GRS190   GEN RHD 3GRFE
JTHBN96S.. UZS190L-BETQKV 01/2005 - 08/2007 UZS190   GCC LHD 3UZFE
JTHBN96S.. UZS190L-BETQKW 01/2005 - 08/2007 UZS190   EUR LHD 3UZFE
JTHBN96S.. UZS190R-BETQKW 01/2005 - 08/2007 UZS190   EUR RHD 3UZFE
As a replacement gearbox i may have access to part number 35010 - 30B20.
I have tried various vehicles and i just cannot pin down to what vehicle this would relate to or to see if it is an A960E at all. Can anyone with more knowledge see if theyt can narrow it down to what car it relates to ?
Search Results
Yeah i should really update my status to show UK , based in East Midlands
So i have had two people come back to me with part numbers for a GS300 gearbox that they have taken off the vehicle . The part number they seem to state which is on the sticker of the gearbox itself is 35010 - 30B20.
I called up Local Lexus dealership and asked if they could check the number on their systems to see which year GS it relates to and nothing ! it does not show up or bring anything up on the system ....seems rather odd
It most probabbly will be like for like but i just wanted to narrow it down to what year or spec so just to be sure and to see what differences they are if any at all
35010 - 30B20
Part number confirmed as A960E suitable for MK3 GS 300 Petrol
Lexus will not recognise number on their systems yet the actual gearbox has a big sticker with the number on it !
  • 1 year later...
