Yes, normal, but can seem scary to those who don't know, particularly when the car has a very empty tank, considerable vacuum pressure builds up inside. They used to have a name something like "foo-foo" valve on old Toyotas which had a special valve to let the pressure out when you twist the cap. They used to call it a foo-foo valve as the hissing noise "used" to make a similar sounding noise.
Remember, you've got a large tank when empty (85 litres).
LOL - a "foo-foo valve" is a common term used to describe something that doesnt really exist / name unknown etc only ever heard it in context to aircraft!
Some of those definitions are just mental!
And not quite on topic but yeah, my fuel cap makes the noise too - it's a good time to let one go and everyone just thinks it's the fuel cap :whistling:
Sorry Colin, I have to disagree!
On my LS400 '94, I have to hang on to the cap (a little exagerated but not much!) to stop it being blown across the forecourt. If it was a vacuum, then it would be difficult to remove the cap!
Surely the pressure is there to aid in petrol delivery to the engine, a partial vacuum would do exactly the opposite.....
Cheers
Dave
I think the EEC system works differently on newer models which is what my link describes. On older systems the tank can have +ve and -ve pressure at certain times. Check valves in the system should prevent either condition getting excessive.
+ve pressure is controls by check valves in the fuel cap and one of the valves in the charcoal canister. -ve pressure is controlled by another valve in the charcoal cansiter.
If you are getting excessive pressure then you should get your charcoal canister checked.
thank you, so where is the EECS then?? near fuel tank, exhaust, throttle? on the shelf in the garage cos they forgot to refit it?? :lol:
talking of which, my garage, after an oil and auto fluid change 'lost' the under-engine protection sheet (fibreboard i guess) and when i asked them to re-fit it, they claimed it was never there! so if you're thinking of using a garage in newbury for your vehicle repairs, PM me first to check that it's not the one i spent £4,000 with!
