Is200 2000 manual gearbox oil change
Tuggle
Hi!
I have recently decided to change the oil in the gearbox as it was not changed since the day it was manufactured. Bought the right 75W-90 oil and the oil pump, but I can’t find the drain plug. Also, when changing the oil, should the both filler and drain plugs as well as gaskets be changed or only gaskets?
