Good morning,
does anybody own or has ordered a UX with a spare tyre?
Or managed to order a spare tyre and fitted it in the trunk, where usually sits the repair kit?
I have a space saver wheel & tyre from my last car, a Lexus IS.
It fits the UX, although I have never used it, nor do I keep it in the car.
There is no space below the lower part of the load area. The space taken up by “cut outs “ for some tools and locking wheel nut sets etc.
Lexus tell us we should not remove the bottom part of the load area as this contains the main battery and should only be removed by a Lexus technician.
As I have run flat Tyres I don’t need a spare wheel.
Thank You.
I bought the space saver wheel & tyre for the Toyota CH-R, it has the same specs as the one for the UX as written in the manuals.
I fitted it on top of the tools, it sits there perfectly. The trunk does not modify, remains exactly the same as without the spare tyre.
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
