Alloy refurbishment
The alloys were suffering from what I believe is known to be a common fault (lacquer peel) and did have the odd kerb rash mark....I chose ' The Wheel Specialist' to sort them. Not the cheapest, but you really want the best job and quality. They have a very high review rating on trustpilot etc and I found the service second to none.
Would recommend to anyone considering needing wheels refurbishedIMG_20220424_171737__01.thumb.jpg.d7fd5f7d5f7b19fa663b4de3fbe1a387.jpg
They all look pretty good right after, the proof will be 1-2 years down the line. If they've done it right = no flaking/peeling.
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
