Engine Rattle At Low Revs
I have had a slight rattle at low revs for some time now so today i went down to my local mechanic and he said that it sounds like a slightly loose timing chain or a worn runner for the chain.
does the IS200 have a timing chain or if not is there anyway of getting hold of a haynes like manual for the car to try and pin point what the problem is.
Hmmmm... timing chain ??
Suggest you find another mechanic :unsure:
IS200 doesn't have one - has a rubber belt instead.
Could maybe be something in a related tensioner / pulley though.
I have checked the heat shields around the exhaust and there dosnt seem to be a problem, i have my money on it being the tensioner bearing, is this a comon problem on the IS200 at around 55k or am i looking for something else.
Any suggestions welcome
Thanks :unsure:
