Tom's Rad Cap
Taz_1
do these fit the GS ?
Not sure, there are two different types. There are also two different pressures available with the TRD one - not sure about Toms but would be an increase over the stock cap.
This Tom's rad cap should fit the GS although has not been tested. Regarding fitment for IS it screws straight on and no modifications required. It is a much better increase than stock cap pressure wise. These normally retail for approx 25-30 GBP.
PLZ NOTE BIDDING WILL END ON SUNDAY AT 8PM
THANKS
:offtopic: sorry ...
Why would one want an increased pressure rad cap ?
Surely it's better that the cap releases pressure than split a hose or worse :unsure:
Am i missing something ? Yes yes.. marbles.. i know :yawn:
THANKS
its a push twist fit, not a screw
it raises the coolant temp, by only a few degrees
This topic is now closed to further replies.
