Fluent German Reader Required
Rob
hi all i have translated the following text but im a bit confused about the last line - can someone have a read and maybe explain a bit more???
Ich biete ein Wasser Kühler der altra klass das in der lage ist ihre CPU's, GPU's zu gefrieren, ein profi gerade das werde auch gebraucht Laser Bennern zu kühlen, vollfunktionsfähig.
cheers rob.
I'm offering a water cooler of the "altra" class that has the opportunity to do something (got a bit lost there)
It is also used to cool laser burners.
In working order.
Rob, when are you comming on MSN again?
hi richie - long time no see, msn ah ha now there is a story i cant get it to work at all, unisntalled/installed etc but no joy - so gave up! :angry:
thanks for the translation - wasnt sure about the laser bit.
I offer a water radiator altra klass in the situation am their CPU's to freeze for GPU's a professional straight that also use laser Bennern to cool, full-functionally. :)
thats the translation i got as well - got a bit confused by the laser bit - all makes sense now though.
