Parking Sensors On An Is200se
pob
Anyone know if it is possible to add parking sensors to a 51 Reg 2001 IS200SE Auto, and how much it would cost?
Phil
You can get some really good quality aftermarket ones...
Fitting will vary from place to place...
Average £200 fitted thereabouts..
If you want to do it yourself... then probally get a kit cheap or check out the links on the forum.
The only one I can find is here:
http://www.parkingsensors.co.uk/taurus.htm
It hasa foil aerial - you really need one that will use the bumper bar. Rodders has one fitted to his GS.
They have some drawbacks - can be affected by rain and don't detect objects unless the vehicle is moving, but look much better than ultrasonic sensors.
I have a two sensor system on my IS ( Lexus/Toyota fit item ), being a blue car the sensors don't stand out that much, but could look a bit of a pimple on a white or silver model ;) .
dont know if my install guide on fitting quanan sensors is still on the forum
if not pm me and ill email it to you
seem to recall paying about 75 quid for the sensors and a tenner to get them painted
fitting was easy and look professional
