Getting Cables To The Boot
tonktedgar
run the cable via the footwell under the carpet edging,pull up the seat base ( if u want) to tuck the cable under, now if u pull back the cushion a bit on the upright part of the rear seat nearest the rear door u will see a hole straight into the boot - easier to see if u have the boot lid open.
stand facing the engine bay - look to the right hand side of the Battery on the bulkhead - you will see a big black rubber gromett with loads of other cable going thru it - put the cable thru this - it comes out in the passenger footwell/behind glovebox.
remember to eal the gromett when u have finished.
