Windscreen Washing Liquid
Duzir
The original windscreen washing liquid is finally running out in my new IS200. I don't particulary like it as it is too soapy. So now it's time to replace it. Can anyone recommend a really good washing liquid that is also safe for the paint? Thanks very much.
I brought a 5litre concenrate from Motorworld because the manual said the IS uses lots of washer fluid. I have had the bottle since october/november only used a 1/10th if that.
Should last me years :whistling:
Oh it was Car Plan
I've used RainX here and it's fine, you get the one applicator bottle then another bottle you add to the windscreen wash mixture - it doesn't replace it as you only use a couple of squirts of RainX in the mixture so it'd freeze up etc..
