Headlights
I've seen quite a few Continental headlights up for grabs, but no UK spec...
So can the EU lights be changed to UK (and pass an MOT) with out the tape on the front?!..
I've got two things planned:
1. Get the inside painted jdm stylie.
2. Reading another post, try something else out... But I'd like a 2nd set to see if it works. (Then pass these on and do the same to what I've got painted, if it works)
I think you will find that it is more to do with the angle the beam is directed I.e over here our ofside light shines higher and lights up more to the left.. i.e hedge. . so I.e in france had you not put on the strips you would blind on comming drivers..
