Supercharger
marcus
yep looks the same and has the same pulley extension on it ( ie 0) only thing is the wiring harness - this might be for an electronic clutch for the SC - mercs have this, but you will need a manifold to bolt onto the bottom of the SC to go to the intercooler pipework -from TTE this is about € 240. and the inlet manifold that has the bypass valve plus the associated shaped tubing etc etc etc and the cradle.
if you do win it, make sure that u get the inlet and outlet manifolds - have no idea about the rest of the kit, brackets, ecu, cradle, tubing,IC etc but u have the core component - so you might just end up with a bargain here!.
ahhh... but which one is he!!
I'm sure one of the other names is from here! :ph34r: (not me though!)
Seems like he has a couple... If was just as seen, what other parts and work would need doing? and would any Merc one fit?
:P it is the same as the IS one mate just made for Mers, lets say i went for this one :whistling: how much am i looking at to get all that i need to get this up and runing :yawn: what would the cost be for all the bits i need :whistling:
how much am i looking at to get all that i need to get this up and runing  what would the cost be for all the bits i need
How much? I'm thinking of asking him about the other one. 100, 200 500?
I need more speed!! :lol:
the other one is not the same as the IS one so it will not fit, but i think he has more than 1, but i need to know how much the rest of the bits are going to cost me befor i start to bid for it as i dont have a lot of cash :whistling:
ok heres a deal............
make the pictures so i can see them......
i will use mt TTE supercharger part numbers list to identify what parts you will require, then i can find the prices for these parts for you.
as before marcus your pictures come out in Gobbligook code format to me
i would be weary............
rotor scoring indicates several different possible problems.
Overheating
Bad filtration , dust induced into blower mechanicals(not good at all)
rotor lobe shift, the lobes(rotors) are moving along there bearing causing rubbing on the body.
would i buy it........nope
what do i have to do so you can see my pic,s :lol:
Overheating
rotor scoring indicates several different possible problems, if you look at all the S/C he has sold they all say that so me thinking he fogot to take it out of the post onec he sold it , if i did buy one i would go and pick it up so i could have a good look, :whistling: or i may just wait and see what comes up :winky:
Maybe he's getting them all when they've been replaced in cars due to problems and that's why they're cheap?
As for the photo problem Marcus, I think it's a problem with the way your host describes the mime type as they work okay in Internet Explorer for me but if I read them in Firefox I just get the binary file pop up...
thats is possibly true as there missing the bottom and rear manifolds....!!!!!
and i think the image problem is also correct i am using firefox
