Sign in to follow this
Fargo
Ptfe Tape And Petrol.
So i was wondering,, is there ant problems with using ptfe tape on a thread tha comes into contact with petrol..
Hard one that i have used it defore but would not like to say deffo .how about leaving a peice of tape in contact with the petrol overnight to see what happens .the only problem i can see is the tape melting like when you use a plastic container etc
Whats this.....ptfe tape and petrol ?
Reminds of sticky back plastic and milk cartons= Blue Peter :lol:
What you up to now Paul.
lol blue peter pah..
well im thinking in terms of my fuel rail,, it is now tapped and a bolt inserted to accept the pipe to the nos pulsoid,, i was having to real really tighten it to stop the leak,, it wasnt a leak as such more of a capilary action leak, a bit like solder and pipes,,
I havnt used the ptfe tape, but i might go back and use it to make sure if there was no reaction witht he tape.
ahhhh yeeehhh..
so whats the deal on that the pete,, what you recommend.
Polytetrafluoroethylene – PTFE (plumbers tape for electricians)
Polymer Type
Thermoplastic
Advantages
Outstanding chemical resistance. Low coefficient of friction. High continuous use temperature (c 180°C/360°F). Very high oxygen index.
Disadvantages
High cost. Low strength and stiffness. Cannot be melt processed. Poor radiation resistance.
Typical Properties
Property
Value
Density (g/cm3)
2.15
Surface Hardness
SD63
Tensile Strength (MPa)
25
Flexural Modulus (GPa)
0.70
Notched Izod (kJ/m)
0.16
Linear Expansion (/°C x 10-5)
15
Elongation at Break (%)
400
Strain at Yield (%)
70
Max. Operating Temp. (°C)
180
Water Absorption (%)
0.01
Oxygen Index (%)
95
Flammability UL94
V0
Volume Resistivity (log ohm.cm)
18
Dielectric Strength (MV/m)
45
Dissipation Factor 1kHz
0.0001
Dielectric Constant 1kHz
2.1
HDT @ 0.45 MPa (°C)
121
HDT @ 1.80 MPa (°C)
54
Material. Drying hrs @ (°C)
NA
Melting Temp. Range (°C)
NA
Mould Shrinkage (%)
NA
Mould Temp. Range (°C)
NA
Applications
Bearings, chemical vessel linings, pipe and valve linings, gaskets, diaphragms, piston rings, high temperature electrical insulation. As a coating for non-stick applications.
looks allright to me :)
Polymer Type
Thermoplastic
Advantages
Disadvantages
Typical Properties
Property
Value
Density (g/cm3)
2.15
Surface Hardness
SD63
25
0.70
Notched Izod (kJ/m)
0.16
15
400
Strain at Yield (%)
70
180
0.01
Oxygen Index (%)
95
Flammability UL94
V0
18
45
0.0001
2.1
HDT @ 0.45 MPa (°C)
121
HDT @ 1.80 MPa (°C)
54
NA
NA
Mould Shrinkage (%)
NA
NA
Applications
hmmmmmmmm, im not sure, have you seen the Dielectric Constant.
Being only 1kHz i have my doubts about its suitability in the application
what about any bits that fall off, and get up my 3mm ID pipe gping to the nos pulsoids..
Polymer Type
Thermoplastic
Advantages
Disadvantages
Typical Properties
Property
Value
Density (g/cm3)
2.15
Surface Hardness
SD63
25
0.70
Notched Izod (kJ/m)
0.16
15
400
Strain at Yield (%)
70
180
0.01
Oxygen Index (%)
95
Flammability UL94
V0
18
45
0.0001
2.1
HDT @ 0.45 MPa (°C)
121
HDT @ 1.80 MPa (°C)
54
NA
NA
Mould Shrinkage (%)
NA
NA
Applications
hmmmm... maybe... but its Flexural Modulus is a whopping 0.70 which would undoubtly be a great asset to the molecular structurisation, and basically would poo all over its dialectric constants ;)
Heat
PTFE retains its properties after exposure to temperatures beyond the limit of almost all other thermoplastics and elastomers. Depending on the end-use requirements, PTFE is rated for continuous service at temperatures as high as 500°F. It also can sustain short exposure at higher temperatures.
Flame Resistance
PTFE offers extraordinary resistance to high temperature and flames because it has a very high melting point and auto-ignition
Temperature, as well as exceptional thermal degradation thresholds. PTFE's flame propagation characteristics, such as rate of heat release and smoke generation is very low.
Friction and Wear
PTFE has one of the lowest coefficients of friction of any solid material. Its abrasions resistance is adaptable to demanding environments by using inorganic fillers, such as glass fiber, carbon or graphite.
Contamination
PTFE is chemically pure and inert. It contains no additives such as lubricants, stabilizers, plasticizers or antioxidants that can contaminate process fluids.
Adhesion / Release
PTFE has an extremely low surface energy in the solid state. This provides an excellent anti-stick, non-wetting contact surface. Conversely, when these resins are in a molten form, they become low surface- tension liquids, ideal for hot melt adhesives.
Low Temperature Service
PTFE retains its excellent properties even at cryogenic temperatures. PTFE's impact resistance at these temperatures exceeds that of most other polymers.
Corrosion
PTFE has excellent chemical resistance. It will resist most aggressive organic and inorganic chemicals, acids and solvents over a broad temperature range.
Service Life
PTFE exhibits excellent retention of properties after a long period of time, even at elevated temperatures and in the presence of oils, solvents, UV light, oxidizing agents and other environmental agents.
Light Stability
PTFE has one of the lowest refractive indexes. It does not change its visual apperance after exposure to ultraviolet or infrared light.
Dielectrics
PTFE has remarkable dielectric strength, low dielectric constant, low loss factors
and high specific resistance. PTFE surpasses most material in its level and stability of dielectric properties over a wide range of environmental conditions.
Biodegradation
PTFE is inert to microbiological and enzymic attack because the pure polymer does not provide any nourishment or porosity for these growths.
Atmospheric Aging
PTFE is not affected by ultraviolet and is resistant to oxidation, discoloration, and embrittlement.
Humidity
PTFE is completely resistant to hydrolysis. PTFE is a good barrier for water permeation. Its typical properties and dimensional stability remain unchanged even after long periods of time in water.
Polymer Type
Thermoplastic
Advantages
Disadvantages
Typical Properties
Property
Value
Density (g/cm3)
2.15
Surface Hardness
SD63
25
0.70
Notched Izod (kJ/m)
0.16
15
400
Strain at Yield (%)
70
180
0.01
Oxygen Index (%)
95
Flammability UL94
V0
18
45
0.0001
2.1
HDT @ 0.45 MPa (°C)
121
HDT @ 1.80 MPa (°C)
54
NA
NA
Mould Shrinkage (%)
NA
NA
Applications
hmmmmmmmm good point, but the Dielectric Constant is more relevant in this perticular case, if it had a reading of 1.5kHz or higher it would be stable for the application.
Having a Flexural Modulus of a (in your words) whopping 0.70 is superflourous in this instance.
Polymer Type
Thermoplastic
Advantages
Disadvantages
Typical Properties
Property
Value
Density (g/cm3)
2.15
Surface Hardness
SD63
25
0.70
Notched Izod (kJ/m)
0.16
15
400
Strain at Yield (%)
70
180
0.01
Oxygen Index (%)
95
Flammability UL94
V0
18
45
0.0001
2.1
HDT @ 0.45 MPa (°C)
121
HDT @ 1.80 MPa (°C)
54
NA
NA
Mould Shrinkage (%)
NA
NA
Applications
i dont think it would be superflourous at all, when you look at the figures for notched izod at only 0.16 kj/m you soon realise how it plays a major part
where as the dielectric constant is only 1kHz but has an overall strength of 45 MV/m this coupled with the dissipation factor of 0.0001 gives a general consistancy in proportion to strawberry flavoured jelly tots
:whistling:
now you mention Jelly Tots that does change the Outstanding chemical resistance, which at its lowest reading should be persistant around c 180°C/360°F, as is the norm.
but you have to remember that this is a Thermoplastic, and therefore the Dielectric Strength (MV/m) is critical in this application where diferential types of Berti Bassets are compounded in the Polytetrafluoroethylene type B-/c+
pmsl .. fargo.. as tony said.. put a piece in petrol and see what happens..
craig
my apologies , you are right ,will admit to not taking into account the compounded types of berti bassets found within Polytetrafluoroethylene this does change the whole molecular structure, but only as a simple formula equation, obviously if the last rolos were equated as well as the berti bassets it could create a whole bag of dolly mixtures,
Sometimes its good to look further than your Malteasers......
s'alright, i got an oanswer over on the wizrd of nos forum
" If your using a parallel thread male into parallel female then you should be using a sealing washer, either copper, alloy or a "dowty" washer. failing that just use "hydraulic seal" or "stud lock and seal" when tightened make sure you leave it 90 minutes before use.
you should still use these sealants if you use tapered threads. PTFE tape has no place on a car, let alone nitrous systems."
There is no problem regarding chemical reaction etc, but there can be a big problem if it is not applied properly and it gets in the system.
The best thing to do is not use it as it is should not be necessary :)
Unless someone has tapped the wrong size hole :blush:
