Fidgits 1 Posted April 26, 2004 Share Posted April 26, 2004 I am having an idea... but i will need a +12V feed from under the dash tray... Now, I would prefer a switched feed, but the key point is I want it to be as easy to get to as possible.. So, after taking the dash tray out, is there a 12V feed I can 'tap' without too much hassle? I will also need the ground.. so can anyone point me to the correct wires (colour as well please).. thanks. Quote Link to post Share on other sites
rajhirani 0 Posted April 26, 2004 Share Posted April 26, 2004 What about the feed coning in to the stereo? Quote Link to post Share on other sites
Fidgits 1 Posted April 26, 2004 Author Share Posted April 26, 2004 cant get to it without taking the stereo out... Ideally, I'd like to be able to get to the feed with only taking the dash tray out.. Quote Link to post Share on other sites
immx 0 Posted April 26, 2004 Share Posted April 26, 2004 You can take an IGN switched 12v+ off the back of the cigg lighter, as for an earth, a ring terminal under one of the gear lever bolts works for me!! B) Or did you mean the top dash tray where the sat nav should be? :duh: Quote Link to post Share on other sites
Fidgits 1 Posted April 26, 2004 Author Share Posted April 26, 2004 Or did you mean the top dash tray where the sat nav should be? :duh: yes Quote Link to post Share on other sites
immx 0 Posted April 26, 2004 Share Posted April 26, 2004 Doh!!!!! Quote Link to post Share on other sites
Gavin G 0 Posted April 26, 2004 Share Posted April 26, 2004 Can you get at the loom going into the back of the clock/heater control panel without taking the radio out There will be a permanent and switched live there for the clock. Just a thought. Gavin :) Quote Link to post Share on other sites
Fidgits 1 Posted April 26, 2004 Author Share Posted April 26, 2004 I can see the wires (just)... can i tap two of them? Quote Link to post Share on other sites
