Paint Work
Ive got a NEW IS300 and over the last few weeks have noticed that around the roof area mainly, when the light catches it I can see blemishes in the paintwork.
My car colour is platinum ice and in total i have seven blemishes (they look like watermarks/birth marks). I have tried polishing them out with Auto Glym Super Resin Polish and even used an abrasive light scratch remover polish first, but these marks are still there.
When i rub my fingers over them you can't feel anything, its almost like the mark was there before the clear lacquered was applied.
Anyone else had this problem on a NEW car?
And what is it, can they be removed??
I shall tell the main dealer, but would rather tackle the problem first myself.
I wont even start on the subject of the car covered in deep scratches when i got it either. :offtopic:
i would complain... get it to the dealers and get them to rectify it.. you have bought perfection and you should expect to see it.
Also abrasives you should be carefull of... if you make a mess of it they will not cover it.
i was told that they were heat spots
due to the covering that they get shipped with
and air bubbles !!
take it back to lexus and they will remove them
using a heat process
as this is under the laquer do not try and polish out !
worth getting a crayon or marker pen and ringing them
as they only seem to show up under certain conditions
Dobedo
Thanks for your reply :)
Heat Spots? I shall speak to the dealer about these and ask how they go about removing them.
Did you have the same problem then?
These marks range from about half and inch to 3 inches long :ohmy:
Dobedo
sure did along with a couple of scratches
one scratch which had been covered with touch up !! :crybaby:
noticed when i picked it up from new
they took it back in two weeks later
and it came out 3 days later
all done
and with a spare set of mats :)
