Replacement Tyres For Sc
McLean
Just coming up to replacing my Dunlop SP Sport 2030's and looking for your recommends. Had a look at http://www.mytyres.co.uk and found wide range to choose anywhere between £100 - £170 each (245/40/18).
Also, anyone know what's different between SP2000 and SP2030 ?
Cheers guys.
  • 1 month later...
Right, got to the bottom of it at last.
The SP2030 version of the SP2000 tyre has been designed to introduce a right hand bias to counter the SC 430 suspension's tendency to steer to the left (allegedly?) when driven over a well-cambered road surface in RHD versions of the car. (And a right bias in LHD versions - so both LH and RH versions of the tyre are available.)
So it seems you can fit what you want, but will have to accept the LH/RH bias unless you fit 2030s - and are prepared to cough up the extra for these tyres.
