Misted Headlamp Glass
Thanks for that. I really didnt want to have to remove them if I could get away with it....... The prob is, there is residue on the inside which looks ******* when the lights are off, I wanted to give em a good buff up inside aswell as dry the bad one out, never mind, looks like a busy weekend ahead......................
Thanks anyway mate
Thanks anyway mate
using t cut or a bit of brasso helps remove scratches from the outside of the lenses. :)
If there is condensation on the inside it will just come back
link
I had the same thing with the mist and the sratches, as seen above. Use brasso on the sratches (takes ages) and they'll look good as new...
see sig :whistling:
