Adding Rca's To Stock Amp.
looking at this guide. RCA outputs have been added on the Rear outputs as they are full range..
will this be work perfectly if i then this to input into say another amp to power the 6 (new) speakers. i understand i will loose fade control (front to rear) but as the guide says i can adjust the levels via the new amps and crossovers..
Secondly if i add a set of RCA's to the INPUT side, will this work perfectly for the sound output from the car PC that i am installing.. would the stereo need to be turned on for the stock amp to power.. if so then does anyone know what the power feed wire is for the stock amp..
