Is200 Auto In Manual Mode?
nctan
IS200 Auto have the following marking at the gear box:
L
2
3
D
Can it behave like a manual transmission? That is we take off from L than move up to 2 than 3 and finally D.
Will it spolit the gear box?
N C
You can do that. The will be a slight delay from when you move the lever to the box actually changing the gear though. Works better going down.
I think you will soon get bored and just leave it in D.
I only use the manual gears to:
provide engine braking
when you are about to overtake so you don't have to wait for the kickdown
when going around a long corner I hold it in gear so you can power out of the bend.
That's called "Gate-Shifting", it works exactly like the E-shift, except you do it manually with a stick rather than electronically with buttons........as in, it allows you to control the top gear the ecu can go to, and allows you to down-shift when you want to....just like an E-shift.....
Be warned....By doing this, you will absolutely Destroy your Automatic Gear Box...
