Carputer Project
  • Replies 143
  • Created
  • Last Reply
Top Posters In This Topic
looks quite interesting, is the old 99 cars wiring on the IS200 the same as the yank is 300's?
i know the plugs are different on the ends but are the colours the same?
and what are those things i drew on the pictures in red?
they look rather rude to me!!
:lol::lol::lol:
dont know is the answer brett,,
And so on too stage 2..
rubbed down with 80 grit and thought i would offer it up for a test fit..
test fit 1
test fit
then i filled in the troughs with soem more liquid plastic and smoothed it a bit more,,
stage 2
stage 2a
gota let that cure then go for a final rub before the painting process.
from here look at Misc Projects...
hte products he uses....products
the liquid plastic i found a distributer in the netherlands,, if you want some i'l; give you his email.. i got the Flexable, semi rigid and rigid ones for 50 euros delivered.
so easy to use that stuff. sands well,.,,
lol i just happen to have some SEM texure paint already..
think thats an undercoat looking at that maties other projects..so yeh lets see what your soft black paint is like mr..
you want the email of the guy in the supplier of the plastic
thought i would splash some texture paint on,, to get an idea of what it would look like.. didnt have time to put the paint in a spray form so just used a paint brush and 1 layer..
here
here
i reckon that might look alright when i get the surface right..
Little tip..
For rough texture spray it from a big distance. Don't spray across. Make sure the item is flat on the floor so the paint sits/lands on the surface. Going in closer makes the texture smoother.
Experiment till you get the texture you desire.. Oh, use primer builder spray for final prep before wet and dry!
ok and so on to stage 3
here
here
used high build primer.. then a quick blast with 800 grit. then some SEM textyred paint (which once dry is a damn good match for the dark grey dash surround.
then sprayed with satin black then some laquer.
i think its a tad to shiny, any suggestions as to hwo i can tone it down.
also the irregular surface aroun the DIN stereo hole will be hidden by the stereo fasica.
as a comparison look at there
http://www.lexusownersclub.com/gallery/Misc/colour_compare
close up
I got mine from as it happens, so they do sell it. I checked last night, it was Satin I used, gives a satisfactory finish, not too dull as I suspect matt might be. Keep us posted with pics... I am looking forward to seeing the results! I finally got a satnav housing, so I can move forward with my little carpc project now too :)
Are you sure the screen is kaput? If you look on www.mp3car.com a lot of the time its just the ribbon cable. Might be worth getting one of those first. I was thinking of ordering one as a spare for when try to fit my Lilli into the satnav. Fisrt issue I have is with the housing being japanese, it seems to have a smaller viewing area than the ones the guys in the US had. I will either have to do some modification of this one, or maybe try ordering using their part numbers and hope its the same as the ones they have illustrated.
Looks pretty sweet mate, well done!
PS.. Hows the blue dash saga going ? :)
