Sign in to follow this
petejenkin
Hks Hiper
Hi guys,
Need some advice. I've ordered a HKS Hiper, and am eagerly awaiting its delivery. Can anyone tell me if any mods are required to the cutout on the rear bumper to take the tail pipe? I hope not!
Thanks chaps
No, it just bolts on... and uses the same supports as the standard back box..
Just a bolt on job.
Undo the two bolts holding your own on. Un-hook the rubber mounts, and reverse to put back on :winky:
Trolley jack should do it.... Haven't changed my zaust, but changed the rubber mounts, just by riding oneside up on the curb...
Depends how comfortable you feel with the car sitting on top of you
Edit: You may want to WD40 the bolts for a bit before trying to undo
Just been down to lexus to get some new exhaust mounts, pricing was very weird??? the rear hanger (metal strip with two rubber hangers on) is about £10 and the single rubber hangers by the back box are £11 each!!! This doesn't make any sense. The guy double checked and said it was correct.
How much did people that have replaced the rubber hangers pay for yours?
I got someone to get my ones for me, that soundsd about right though..... If your just replacing your zaust I wouldn't both changing the mounts..
I only did my one's cuz there was a hot rubber smell after hard driving (which I found out later is normal! :lol: )
I'm only going to change them to get rid of the rubber smell. Though I might as well do it whilst changing the exhaust. Do you still get the smell with new mounts?
Not to start off with, but its come back a bit now after a few months.. I'd just give them a good scrub.
Then it will all be changed in just a coulpe of mins :winky:
please also use axle stands :o
there only about a tenner from machine mart :)
and remember to choc those front wheels :unsure:
opps... Forgot to say that
I used them everytime :whistling:
I've got some axle stands. Have just been under.... Damm those bolts are tight. Given em a good soaking in WD40, will try again tomorrow
Try undoing the bolts while the exhaust's still hot. They come out much easier cause the zorst has expanded !!
Mine did anyway !
Cheers Duncan, just have to be carefull not to burn my arms on the rest of the exhaust
Wear a long sleaved jumper... :duh:
any hints for putting one on easier without a ramp?
mines lowered as well
i got a piece of wood about 3 inches thick,reversed my lex onto it to get under,i dont like jacks. :)
Brother has a pit in his garage, rather handy! :winky:
I just got my HKS Silent Hi-Power this morning, and was waqndering if the gasket on the end of the standard pipe will go straight onto the end of the new one, if theres a gasket there at all!
Anyone?
Stu
There wasn't one in there when I fitted it on mine Stu
