New Key To Be Added For .......
RIGHT SECOND OF TONIGHTS TIT-BITS . :hehe:
PROGRAMMING A KEY TO USE WITH THE IMMOBILIZER .
HOW - BLACK KEY .
WITH THE PROGRAMMED BLACK KEY INSERT INTO THE IGNITION SWITCH .
WITHIN 15 SECONDS PRESS AND RELEASE THE ACCELERATOR 5 TIMES .
WITHIN 20 SECONDS .
PRESS AND RELEASE THE BRAKE PEDAL 6 TIMES .
REMOVE THE BLACK KEY .
WITHIN 10 SECONDS : INSERT BLACK KEY TO BE PROGRAMMED INTO THE IGNITION SWITCH .
WITHIN 10 SECONDS : PRESS AND RELEASE ACCELERATOR PEDAL ONCE .
IMMOBILIZER WARNING LAMP WILL FLASH .
AFTER 1 MINUTE IMMOBILIZER WARNING LAMP WILL GO OUT .
NOTE --- TO EXIT PROGRAMMING MODE : REMOVE IGNITION KEY AND PRESS BRAKE PEDAL AT LEAST ONCE WITHIN 10 SECONDS .
NOTE --- A MAXIMUM OF 7 KEYS CAN BE PROGRAMMED .
GREY KEY - HOW TOO .
INSERT BLACK PROGRAMMED KEY INTO THE IGNITION .
WITHIN 15 SECONDSPRESS AND RELEASE ACCELRATOR PEDAL 4 TIMES .
WITHIN 20 SECONDS : PRESS AND RELEASE BRAKE PEDAL 5 TIMES .
REMOVE BLACK KEY .
WITHIN 10 SECONDS : INSERT GREY KEY TO BE PROGRAMMED INTO THE IGNITION SWITCH .
NOTE --- A MAXIMUM O 3 GREY KEYS CAN BE USED .
HOPE THAT HELPS SOMEONE . B)
GOOD LUCK .
JON .
Will this program a new master?........three button(boot release) key
I understood that you cant make another key from a valet key (a master must be used)?
Black key = master
grey key = valet
I'm not 100% sure this procedure works. I've tried it before and couldn't get it working.
Can anybody with a UK IS200 workshop manual confirm this?
