Sign in to follow this
Fargo
Oem Gps Unit
So people,
anyone know where the stock GPS receiver is for he sat nav in the IS..
dunno, is it,, thats a shame,, was hoping to use it for somehitng else.
i think its on the rear parcel shelf
underneath i assume, in between the outer carpet thing and the metal inner, ill have to have a butch..
does anyone now what tyep/standard it is/complies to..
I believe the GPS receiver is part of the main Sat Nav unit in the boot and the GPS aerial is located on the rear shelf.
This is an aside, but why does my satnav get quite confused when its in central london? is that normal (because all the streets are so close together) or something i should have checked?
Are you still receiving a signal when it goes wrong?
thats a good question, i'm not sure. How do I know if there is still a signal?
Depending on version you either get a green GPS icon on screen or nothing when you have a signal and a red GPS icon or a GPS icon with a line/cross through it when you don't.
ok thanks for that, i'll keep a look out for it when i'm next in london, because it never seems to have any trouble except when in central london
In some situations, the GPS signals can bounce off tall buildings before reaching your car - this can confuse the system that works out your position.
on the earlier models the antenna is on the dash next to the auto headlamp sensor
i guess its the same on the later ones too.
Can you see it or is it hidden?
Thats not correct,
the 2 "blobs" on the dash, which incedently European mainland models dont have are for.
1. light sensor. for auto headlights (non-euro fitment)
2. Solar sensor for the air conditioning and climate control
yes your right mat :blush: i stand corrected
i was thinking of some of the toyotas they have it on the dash like that
i will crawl back under my stone.
john :duh:
