Blank Buttons For The Is
Does anyone know if there are any blank or almost blank switches for the IS. The swiches like seatheater, foglight, TRC|snow and so on.
Or is it even possible to print them with custom text?
if i think right there is one on the left hand side of the steering wheel as the console sweeps under . there is a blank there next to the a/c temp sender (i think) .
But thats not a button?
I need a button that shows no or almost no text, so I can make it hold a new function.
why would toyota make a switch ..........that did nothing :duh:
why not get another switch and put black tape over it
it can actually do something, but should only have a lamp, or no text on it.
Maybe Toyota thought of guys like me? :whistling:
Black tape? Hope thats not looking too ugly... :duh:
i
not if you do it properly.................
If the standard switch is etched just rub it down with fine wet and dry then metal polish to remove the existing symbol / text the you will have a blank - did it once on a ford but depend how deep the etching is ...
