Sign in to follow this
roobybaby
Removing The Factory Radio
Just joined the forrum, so not sure if this has been asked before, but how do you remove the stock radio.cd.cassette unit from an IS200? Im totally clueless :o
Any help would be much appreciated......
Cheers,
put your hand on top of the dash tray and pull towards you,it will unclip,put your hand flat under the bottom of the console where the heated seat switches are and pull towards you.you will see the bolts that hold the stereo in,remove and volla.be carefull when taking it out cause the clips on the sides near the top on the stereo will mark your dash,good luck dude. :winky:
Thanks BESTY it always seems simple once you know how :winky:
no probs mate,i was like you but wid the help of the lads i`m learning fast,there a good bunch :winky:
IF PEOPLE LOOK IN THE WORKSHOP / KNOWLEDGE SECTION THEN U WILL FIND A HIGHLY DETAILED STEP BY STEP SET OF INTRUCTIONS WITH PHOTOS !!!
Top right....LOC navigation.
Feel the force jedi.
hook line and stinker ,,pete
Is mine the same then with the lidded top tray ?
Just get a firm grip and slide the top bit forward and it will unclip and slide off ?
yeh,give it a good pull towards ye.it will seem tight. :)
