Altezza/is200 Grounding Kit?
Maz
yes, but not really worth it other than the bling factor...maybe some improvement to shifting in an Auto........maybe
bling factor that why Im getting it Mat....hehehe B) B) :whistling::whistling::whistling: , so the Altezza kit will fit my IS then Mat?
Zee's circle part (where all the cables connect) fits on top of the wheel arch, then a set of cables goes off from here to the various points, and another set grounds on to the "-" Battery terminal.
My one you take apart the terminal connector and bolt it straight onto the Battery, and one lot of cables goes off from there. (see pic) I also had to chop about 6mm of the part the circle sits on, as it kept touching the bonnet.
pic
My one (£8!)
zees
