Sign in to follow this
BESTY
Spark Plugs Is 200
whats the gap size for the plugs on the 200,cant find it anyware.cheers lads. :)
Should be set when you get them.
It says in the handbook(page 240)...ONLY USE iridium TIPPED S/PLUGS AND DO NOT UDJUST GAPS FOR YOUR ENGINE PERFORMANCE AND SMOOTH DRIVABILITY.
:excl::excl:
You should check the gap when you first put them in but they should already be correctly set at 1.1mm
thanks loads colin i`ll do that. :winky:
