Prolex-uk Latest Offer
Dave-Ellen
OK,
How about 4 top quality flush fitting reversing sensors for £135 + P&P ???
Easy to fit (1 or 2 hours max)
drill 4 * 22mm in your rear bumper, thread the wire through.....connect to control box connect to reversing light attach speaker to underneath of rear parcel shelf........bingo.......
could be the bargain of the century.......... :P
Those of you wary of fitting :blush: I may be be able to arrange this as well at a reasonable cost.
interested ? email me at prolexuk at ao'ell dot com
Can these be fitted to the front aswell?
They can indeed. But you'd probably need a switch to switch them on when parking as the reears work when current is going to the reversing lights.
Hope that helps
Sometimes the metal bumper bar can cause problems with these systems although the web site does say it works with a metal bumper.
Rodders has this type of device although I think his one uses the actual bumper bar as an aerial rather than the foil tape to stop any problems with interference.
