Sign in to follow this
SHAHZ
Bonnet Lining
I want to change my washer jets. To remove the lining on the inside of the bonnet do the round fixture plugs just pull out?
TIA
No need to remove the lining. Slid something between top of bonnet and jet to push in the clip and it will pull off. Just keep hold of the pipe so it doesn't drop down through the hole.
:unsure: how or what am i going to do this with out scratching bonnet??
Take your creditcard. Push it under the washerjet from front, than from rear and lift it up with the other hand (gently). It will clip off. Take care of the pipe.
Shahz,
I changed my washer jets yesterday and it literally took a couple of minutes. I used a small flat screwdriver wrapped in some cloth to prise the old ones out. As Phonedrome and Colin have said, make sure you keep hold of the pipe!
The new fan spray jets work a treat - a big thanks to Chris Shipley for sorting.
Cheers,
Sandeep
Cheers guys....as soon as the :tsktsk: rain stops ill go out and put them on B)
No there hasn't been a group buy yet.
Eh :o so what was all the names up on a thread a couple of weeks ago?
I asked Chris if it was possible to do a GB.....but said to pm him as he was to busy to do a GB at the time .......He then got bombarded with PMs...poor geezer...there were a lot of people that put thier names down.... i know three of us have got them :shifty: :winky: top bloke our Chris B)
They were £16....just fitted them a few hours ago :D
they make alot better use of the water and give better coverage if you've got Rain X on your windscreen
