The Wilo 0 Posted July 13, 2004 Share Posted July 13, 2004 On my lex when i press the boot relese on the key fob or the pull handel in the car the boot does open but does not fully open on other IS's any idea what might be the problem?? Quote Link to post Share on other sites
Parthiban 3 Posted July 13, 2004 Share Posted July 13, 2004 Do you mean about it opening completely? Generally different people's boots open different amounts. When mine was just popping open, but not lifting at all, I took it to the dealer and they replaced the boot springs which made it open all the way off the keyfob. But now just over a year later, it only opens half way, and soon it'll probably stop altogether. Quote Link to post Share on other sites
rajhirani 0 Posted July 13, 2004 Share Posted July 13, 2004 Hi mate i had the same problem, and then found some of the members here have out cut and tie clips to put more tension in the springs, i have done this and now my boot opens 3/4 of the way, much better than before. hope this helps Raj Quote Link to post Share on other sites
The Wilo 0 Posted July 13, 2004 Author Share Posted July 13, 2004 cheers my boot only opens about 1cm i have to manually open to the full amount, how much for the dealers to replace the boot springs?? Quote Link to post Share on other sites
LennyLexus 7 Posted July 13, 2004 Share Posted July 13, 2004 cheersmy boot only opens about 1cm i have to manually open to the full amount, how much for the dealers to replace the boot springs?? its because you now have a spoiler fitted ;) Quote Link to post Share on other sites
PhoneDrome 0 Posted July 13, 2004 Share Posted July 13, 2004 Does sombody have the P/N of the stiffer springs? Perhaps some oil would help (only if no spoiler is fitted). Sometimes even the license-frame is to heavy for the springs to open the boot completly (US-frames in metall/chrome). So if somebody have a number for the springs....... Quote Link to post Share on other sites
ColinBarber 1,916 Posted July 13, 2004 Share Posted July 13, 2004 There aren't stiffer springs some just seem to open the boot more than others. If you have a spoiler then it probably won't lift at all. Don't think the boot was even designed to fully open. Quote Link to post Share on other sites
Wosket 0 Posted July 13, 2004 Share Posted July 13, 2004 my boot barely lifts 1cm, lexus say its down to the spoiler. Quote Link to post Share on other sites
Claire G 0 Posted July 13, 2004 Share Posted July 13, 2004 Had similar problems with mine. Lexus replaced the springs under warranty (had an IS200 Sport at the time) and after a few months it was back to opening just a crack. Nothing they could do further and the weight of the spoiler means it opens less than others anyway. If you can live with it I wouldn't bother forking out for new springs. Quote Link to post Share on other sites
Wosket 0 Posted July 13, 2004 Share Posted July 13, 2004 If you can live with it I wouldn't bother forking out for new springs. yeah, u get used to it mate Quote Link to post Share on other sites
rajhirani 0 Posted July 13, 2004 Share Posted July 13, 2004 Lexus replaced my springs as well and a few months later they went back to normal. but when i was speaking to the guy there he told that they do two springs ones a stiffer spring which they fit to the is sport models. Quote Link to post Share on other sites
The Wilo 0 Posted July 13, 2004 Author Share Posted July 13, 2004 cheers for all the info i will just leave it as it seems to be a common problem as i have the spoiler on it. Quote Link to post Share on other sites
Drummerboy 0 Posted July 13, 2004 Share Posted July 13, 2004 Mine used to open about half way for the first 5 weeks I had the car........... then I got run into and now it barely pops the catch Just grin :) and bear it Quote Link to post Share on other sites
Wosket 0 Posted July 13, 2004 Share Posted July 13, 2004 Lexus replaced my springs as well and a few months later they went back to normal. but when i was speaking to the guy there he told that they do two springs ones a stiffer spring which they fit to the is sport models. is that on the revised sport models? Quote Link to post Share on other sites
PaulTulley 0 Posted July 13, 2004 Share Posted July 13, 2004 If you park facing downhill then it'll open all the way! ;) Quote Link to post Share on other sites
The Wilo 0 Posted July 13, 2004 Author Share Posted July 13, 2004 is that lexus's offical fix :winky: :winky: :winky: Quote Link to post Share on other sites
PaulTulley 0 Posted July 13, 2004 Share Posted July 13, 2004 Yep - apart from the Dutch market! Actually, my boot sometimes doesn't open, but seems to work better after washing the car. Quote Link to post Share on other sites
Wosket 0 Posted July 13, 2004 Share Posted July 13, 2004 Mine used to open about half way for the first 5 weeks I had the car........... then I got run into and now it barely pops the catch Just grin :) and bear it ur signature pic is massive!!!!!!!!!! :o Quote Link to post Share on other sites
ColinBarber 1,916 Posted July 13, 2004 Share Posted July 13, 2004 It's worth cleaning the boot seal with silicone lubricant as the seal can stick to the boot lid and stop it coming up. Quote Link to post Share on other sites
whitie 0 Posted July 13, 2004 Share Posted July 13, 2004 I like to think my one has its own little personality, it opens how much it wants to :duh: Quote Link to post Share on other sites
Sipey 0 Posted July 13, 2004 Share Posted July 13, 2004 If you open the boot on a windy day with the rear end of the car facing the gale I find the boot lid shoots right up in the air then dissapears over the top of the car. Joking aside, and not wishing to speak out of turn guys, but does it really matter how far it opens?? Mine sometimes opens about 1cm as Wosket said, other times it opens all the way. Now if I had paid the £x amount on a S600 Merc or Rolls where the boot opens and closes off of the key fob, I might get a little miffed if it didn't work. Quote Link to post Share on other sites
Maz 0 Posted July 13, 2004 Share Posted July 13, 2004 my open fully.............but i need to use my hand............. Quote Link to post Share on other sites
whitie 0 Posted July 13, 2004 Share Posted July 13, 2004 but does it really matter how far it opens?? Depends if I want to put the Stella's on the ground Quote Link to post Share on other sites
Monster-Mat 12 Posted July 13, 2004 Share Posted July 13, 2004 there are stiffer springs.but i cannot be ****d finding the part number, i have a pair in my storeroom Quote Link to post Share on other sites
Sipey 0 Posted July 13, 2004 Share Posted July 13, 2004 Depends if I want to put the Stella's on the groundPoint taken - but as Maz said whitie, you could use your hand to open the boof before removing the stella's from the trolley. Or you could try towing a fan that switches on when you press the boot release button :P Quote Link to post Share on other sites
