Advice On Alloy Wheels...
rocky786
Hi rocky...if you have the standard wheels fitted on your soarer,stamped on the inside or outside of the wheel will be the offset number...on my mk1 LS 400 it was stamped on the outside...on me LS the offset was 50...
If you fit the wrong offset the wheel will be to far inside or outside of the wheel arch causing it to rub on the wheel arch...also i dont know what type or size the calipers are on your soarer but that could be another problem,the calipers may rub the inside of the alloys.
Good luck.
Hi All,
Im intrested in buying some alloys...and wanted to know if the alloys and tyres would fit my soarer (1992 - 2.5 TT).
The alloys measuremnts are 225x40x18r (18")...
Can anyone advise me...?
Thanx...
-R
:zee:
If 18"s fit size will be F 8.5J 245/40-18 and R 9J 275/35-18 or F/R 8.5J 245/45-18.
Offset will be 35-40.
