Boost Gauges
aido
OK I'm just thinking about getting a boost guage to keep an eye on stuff when I hit problems, are they easy to fit?
How do they work - and where do they connect to get the reading from?
TIA
Very easy to fit, well, it was on my Impreza. If you look at your inlet manifold, look around for a removable cap where you can attach the tube which connects the gauge. Make sure you get a good tight seal. Route the tube into the cabin, hook up the gauge, don't forget your illumination.. job done.
